1 - 16 of 16 Posts
Hi guys what does this button do it highlights when on? The single switch bottom of image
531396
I Have Imaginary Friends
Patrol Hybrid.
Looks aftermarket to me.
Reactions: grumpyone and dkril
1989 GQ TD42 wagon
Definitely aftermarket. Either trace the wires, or turn it on and off until you work out what it's for.
Keep in mind that it may be disconnected.
Pass the Popcorn
Nissan Datsun Patrol
I'd check for wiring around the bullbar/front grill if nothing obvious happens when you turn it on and off.
Patrol Y60 GR from Spain
Well there was a idler knob there from factory but someone has removed it and replaced with aftermarket switch. You will have to trace wires and turn on and off to notice any changes as stated above.
Possibly a switch installed for manual glow plug..
1989 GQ TD42 wagon
In a RHD drive car (which I believe this is), the hand throttle is on the RHS of the steering wheel. The mystery switch is on the left.
Hi My 2012 patrol has one like that pulled it out no wires attached but mine is in a different place but it could come in handy
My GQ has an identical one and it is to turn on aftermarket LED spotlights.
2002 3.0 Litre DI, auto, 2 inch lift, 33inch KO 2s
It could be a turbo timer. Mine has a switch and light arrangement very similar to this.
1 - 16 of 16 Posts
