1 - 16 of 16 Posts
hey guy's got the car tuned after the 2860 when't on,and i put out 96.6kw atw and 345nm of the good stuff.but with 35's and 4.11 diff ratio's what would those figure's be if my finale gear ratio was factory?
almost impossible to be able to know. so many factors to consider it wouldnt be accurate. put some 31s on it and get it re dynoed. bout the only way you will know for sure. or pull the engine and get in on an engine dyno.
yeah im not that keen to know i just thought some one might be good with the calcalator.cheers any way benos
I'm tippin a minimum of 20rwkw loss running 35's
Your power curve should be plotted against engine revs and hence it makes no significant difference
what tyres or diff ratio or other gearing you have.
Think about it for a minute - if you change gears your engine is still the same.
There is a small loss (or gain) with 35 tyres if they are wider than standard or big knobs , due to flex in rubber but this can be overcome by upping the pressures in the tyres.
rubber - but
There can be up to a 20kw loss due to large or chunky tyres. They take more effort to drive and also suffer windage. Higher tyre pressures help, but 20kw is still a large loss, especially if its running between 90-130 rwkw.
Autos are Superior
I know... I want my 20kw and 100nm back... :( Help me!
I would assume around 35% loss via the driveline diffs and tyres.
I built a V8 and input the details into the cam builders comuter program and we reckoned on about 280 hp at the flywheel.
Running through an auto and transfer case, with 35" pedes and 4.1 gears it came in at just shy of 180 rwhp. An auto will suck a bit more power than a manual too.
So 97ish kw is roughly equal to 149kw or 199hp at the flywheel, and 345nm is around 530 at the flywheel.
You are better using a power amount to determine driveline losses. Otherwise if you had a 35% loss on 100fwkw you are at 65 rwkw, if you had 200fwkw, that means you have lost 70, which isn't true. Most patrol with td42t vehicles dyno at 65-80rwkw. Std is 118fwkw I think, that gives you roughly a 40 kw driveline loss.
Andy
Discussion Starter #12
cheer's andy so ya think it will be around the 120 and 450 nm?
Do you like how it drives?
Yes? Then forget the numbers and throw the bit of paper in the bin.
No? open your wallet some more.
Discussion Starter #14
lol yeah mate that i do, the wallet will be open again in a couple of month's so we will see if i go further with it
Post up your graph so we can have a look. I think 120 would be very close, or put 31's back on and get it redynoed. Then drive it, you may not want the 35's back on.
Andy
Autos are Superior
Great advice!!!
1 - 16 of 16 Posts
