1 - 12 of 12 Posts
Nissan Patrol GRX 2003
Hi all,
I have an issue with my ride...
1-check engine light on (sometimes normal when engine is restarted)
2-lost a bit of power (when check engine light is on)
3-engine hard to run over 2100-2400 rpm
4-while check engine is on with the issue...sometimes runs normal, sometimes lost a bit of power
Anything has any experience with this issue?? any opinion?
ps. just repaired my intercooler, this started the 2nd day after intercooler is repaired, but I think this has nothing to see with the intercooler, maybe just coincidence.
Hi all,
Anthony, Hi, Dirty fuel will bring up 0707 code (injection timing)caused by low fuel pressure, check filter!!
Cheers Macca 8)
Sounds like either MAF or fuel filter I have had the same issue with both problems. Down load the ZD30 document at the top of the GU forum and it will tell you how to recall the codes.
We had the same problem with ours, engine light on so thought it might have been water or air in the fuel, drained it still didn`t fix it, change the MAF and that fixed it, running better than ever, maybe it hadn`t been change yet after doing 143000.as it is second hand 1.
Maf
thanks all,
so...can anyone tell me where is the MAF, and how it look.
There seem to be many causes of your problem, I would go with some others and suggest the Mass Airflow Sensor. I would also suggest you visit a good mechanic and speak to him about your problem and mention the Mass Airflow Sensor. Good luck
1 - 12 of 12 Posts
