14941 - 14960 of 14997 Posts
I got some 1000L pods off a mate awhile ago.yesterday had a crack at cutting one down.had a go at plastic welding it,did no good with soldering iron or heat gun(with minimal effort).one piece over lapping sides 3/4 tube of 1/2 good sikaflex.
I Have Imaginary Friends
Patrol Hybrid.
Plastic welding is not difficult, except you need the right filler rods and some ‘plastics’ aren’t designed to be welded. Sika will be your friend.
Cleaned the K&N,re-oiled it,adjusted the valves,have to re-seal the sump one day,somewhere in the past the engine was lifted with a wire sling under it and its distorted.
Redid it about 12mths ago but it's impossible to not squeeze out the sealant along one edge while starting the bolts on another and anyone who has had a sump off knows the oil just runs down the inside of the crankcase --forever !! so getting a dry mating surface is like shearing jellyfish.
GUII ZD30DI Wgn
Fitted new serpentine and the good bushes to old belt tensioner. Thanks @geordie4x4 had these bushes on the shelf a long time :)
524042
2003 GU PATROL
How come you strip it down that much to do belt/tensioner? Or you doing other things?
GUII ZD30DI Wgn
Started designing tray head board.
Started with dodgy drawings on phone.
Then did measurements and chalk drawing on garage floor, followed by arts and craft time with old carboard rolls.
Think im happy with design.
Now bunnings just needs to get new gas bottles in and ill grab the needed metal.
Thinking 50nb pipe. Will all be just cut and welded.
Sent from my SM-A515F using Tapatalk
GUII ZD30DI Wgn
Replaced oil filter/cooler assembly with a second hand unit from Patrolapart, stripped it completely and flushed it out just to be sure.
524072
300,000 K service....timing belt and idlers...front crank seal...new water pump...recon standard alternater.... all new drive belts....block flush and new genuine ally radiater...front diff oil changed...overflow bottle got the vinegar and bi-carb treatment , can see the level lines now....new fuel filter... new air filter and normal 5000k oil change . Still to do.....remove r/h back axle and fix weepy diff oil seal....change gearbox, transfer, and rear diff at 320,000 k ....all with synthetic gear oils...
and then look out OZ...we are off....hopefully....
Cheers Keith
GUII ZD30DI Wgn
Charged both batteries, getting ready to start the old girl in a few days. @Yeti's Beast Brad, that Victron 12v7a IP65 smart charger is a bloody beauty as is the deep cycle PHC12/100 AGM I got through you, thanks again.
any chance of a pic Keith?
Didnt think of that hey....and not sure how to post one on here anyway....but if you have seen a new genuine overflow....pretty much what it looks like with a few outside marks added for good measure.
Cheers Keith
GUII ZD30DI Wgn
Cheers Keith
Go to the 'sandbox' section, there is a sticky there that explains how to add pics to the forum.
GUII ZD30DI Wgn
New throttle cable in and lpg tune yesterday. Original cable only lasted 535000 ks.
Holy Moly, I'd be contacting the ACCC.
