@Ethanissan
Given all that works and your happy with it. How hard do you think it’ll be to cut the bracket off the “air box” to rotate the inlet to face the snorkel opening and weld the bracket back on. Therefore you only need a straight silicone bend for connection.
Not sure. I do know what you mean, and it would require drilling out all of the spot welds on both brackets (there’s 2 that attach it to the firewall, 4 bolts total), and re-welding them in a different spot afterwards. My only real concern would be that They need to be welded in exactly the right spot, since there’s 2 of them and if one is lopsided or wonky it won’t line up. Also drilling out the welds will also require them to be filled back up again.
Probably will happen eventually as I don’t like the sharp 180* bend that the air has to take from the snorkel into the airbox, but not hugely high on the list of priorities.
On a side note, Dad’s farm Ute already has either an aftermarket airbox or an original one with this very mod done to it. The outlet faces right into the snorkel hole, much better than mine.
Maybe that’s just how the factory snorkel models came and my airbox is just from an N/A? I dunno.
