1 - 2 of 2 Posts
nissan patrol gq
Howdy, just installed my new Pertronix 2 and Flamethrower 2 today, easy as, removed all the required parts including the points, condensor, ballast and fitted the good stuff, fired on first go, no problem with this, what I need to know is on the ballast there is a black wire that leads to what looks like another condensor and a connector on the other side it sits just in front of the coil and under the pre-cleaner, the problem is that the othr end should connect to something but it's just hanging loose, where the does this condensor looking thing connect to and is it an important bit, any help appreciated.
Les
It's a noise suppressor.
Supposed to connect to the block. I pulled mine off but I run a completely different ignition system now.
1 - 2 of 2 Posts
