5601 - 5620 of 5671 Posts
I Have Imaginary Friends
Patrol Hybrid.
Reactions: Foo and Softy
just a good guy.
2009 gu ute
That thing should be almost brand new now. ;) It would only need the steering wheel nut replacing now. ;)😇
Foo
Battery 4 years old and starter was original one with half million kms on it.
Reactions: Foo
Triton n Lovin it.
Like I said, it should be nearly a new vehicle now. ;)
Foo
Here To Be Entertained
Currently not a vehicle owner
Offering up the suggestion of a nine day fortnight and being met with "yeah, that's actually a pretty good idea"
See if it makes it into reality any time this decade :unsure:
And yes yes I know, half you blokes are on permanent zero day fortnights ;)
Triton n Lovin it.
So long as you still work 40hrs as a minimum.
Foo
Sent from my SM-T510 using Tapatalk
Reactions: GUEY
Triton n Lovin it.
When the plumber comes to check out a damp wall and it ends up being a leak upstairs and not my problem!
But that wouldn't matter anyway, as you're the paying tenant! ;) They will still make a mess in your joint, to repair the effected area. 😁
Foo
2003 GU PATROL
Foo
Incorrect. The pipe is on the outside wall plumber said they will remove the external bricks to get at it and fix it.
Triton n Lovin it.
Well how did you know the damp was there or didn't you know about the wet? 😕
Foo
Triton n Lovin it.
Reactions: Yeti's Beast
Patrol Hybrid.
