1 - 9 of 9 Posts
I've heard that there can be some fitment issues with some winches in Patrol bars. I dont want to be messing around with mods to the bar to make a winch fit, so want to find a winch that will fit into my GU series 4 ARB sahara bar without any dramas.
Im looking at the cheaper end of the price scale but would be interested in hearing about any winches, so I can compare sizing specs.
So the question I ask is.......
What winch have you fitted in a GU series 4 (or later) ARB Bar without any modification to the bar ?
thanks in advance
They still use the standard winch bolt patern for the mounting so almost any (low mount) winch on the market from 8000lb to 12,0000lb capacity will fit. Only some of the bigger 12,000lb and 14,000lbs may have issues.
I have a Mako Avenger TDS 9.5 and it is an easy fit and easy to get at in the ARB Delux winch bar. I don't think the Sahara bar is any different.
The only issues I have ever seen on an ARB Delux bar is that the mounting for the roller fairlead (only needed on a steel cable winch) is designed for the Warn and Magnum winches that ARB sell and is a tight fit for some other fairleads.
Rogue
nissan gu patrol
Warn 9.5XP
The new Warn Zeon's are a bit quedtionable however I suspect they do (haven't had a chance to see one installed yet) however the rest of the Warns (up to 12,000lb), Bushranger and Smittybilt winches fit. Also seen Runva, Ironman, Avenger, Roo, ect ect. There's more room in the ARB bar than the factory bar, most winches fit easily.
Discussion Starter #8
Thanks guys. Seems like most will fit. Now just have to decide how far the budget can stretch.
There seems to be enough room to do the install without removing the front bar from the vehicle. Does that sound right or did you need to remove the bar ?
Discussion Starter #9
Just had a poke around on youtube and found videos of Simon from 4WD TV installing a winch into the ARB bar on his Patrol. There is a series of short videos which covers the entire install. Looks to be a piece of cake. Bar doesnt need to come off.
Here's the link if anyone interested.
https://www.youtube.com/watch?v=bdHN7SqA-bI
1 - 9 of 9 Posts
