Wow that would be a fairly rare and serious issueCrack in the chassis near the steering box. Welded up and plated and no more wobble.
Were your brake disks warped?@Boundry Rider
Check the brakes mate. Once I did the brakes in combination with other things my wobble have gone. I did a full brake rebuild (calipers) and new rotors and pads all around. Now she stops like a beast and no more wobble
Yep. Just enough to throw it outWere your brake disks warped?
Was the brake pedal pulsing while braking?Yep. Just enough to throw it out
No not noticablyWas the brake pedal pulsing while braking?
I would say these are the most common culprits.it looks to be the panhard rod bushes that fixed it
True, the loads on the road are much heavier than what can be exerted by hand.No play in my panhard bushes with someone rocking side to side. Unbolted from diff and could rotate rod quite easy. Replaced bushes and vibration gone.
Lesson is don't rely on any side to side movement to determine bushes are worn.
Surely that suggests that the problem is primarily wheel balance?Now after all that time I had a wheel rotation and bang....head shakes going into violent shakes.
Yes indeed mate, I think that is a fair and logical conclusion to arrive at.....however it always pays to check all the bases! I remember many years back after a wheel balance and rotation on my old GQ I had a similar thing happen, I had the car back there 3 times, was fuming and vocalised my displeasure only to find the next week that my driver side radius arm bushes had flogged out....got them replaced and hey presto all good. So with that in mind I got under the GU on Sunday morning with spanners and pry bar and started going over everything....what did I find??? Totally flogged out lower (diff side) panhard bush and the nut was also loose no doubt because the bush is flogged out and it has been slapping about. I picked up some replacement bushes yesterday and will replace them asap. I am happy that I ordered the adjustable drag link because that will finally fix the off centred steering wheel I have been living with.....and I am also happy this has pushed me to get the steering box rebuilt as I have been living with additional play in the steering wheel for the last couple of years as well. All of this should bring the old girl back to near new steering...….Surely that suggests that the problem is primarily wheel balance?
Wheel balance was intentionally left out of the top 10 fix's, at the time there was a rash of 'death wobble' threads so this thread was started based on feedback, the reason for omitting balance was because it's expected that is the first port of call for elimination being very easy and a commonly known start point.Yes indeed mate, I think that is a fair and logical conclusion to arrive at.....however it always pays to check all the bases! I remember many years back after a wheel balance and rotation on my old GQ I had a similar thing happen, I had the car back there 3 times, was fuming and vocalised my displeasure only to find the next week that my driver side radius arm bushes had flogged out....got them replaced and hey presto all good. So with that in mind I got under the GU on Sunday morning with spanners and pry bar and started going over everything....what did I find??? Totally flogged out lower (diff side) panhard bush and the nut was also loose no doubt because the bush is flogged out and it has been slapping about. I picked up some replacement bushes yesterday and will replace them asap. I am happy that I ordered the adjustable drag link because that will finally fix the off centred steering wheel I have been living with.....and I am also happy this has pushed me to get the steering box rebuilt as I have been living with additional play in the steering wheel for the last couple of years as well. All of this should bring the old girl back to near new steering...….
I will let you know how the panhard bush replacement goes and then again after I replace the other stuff and get the sterering box overhauled.
If new rims fixed it then there would have to be something wrong with the old ones which I expect should have been picked up while balancing.So, while not on the voted list of fixes, rims are what ended up fixing my problems.
