1 - 19 of 19 Posts
This is how we roll.
More water, cement and diesel today. I just cant carry it 3 kms on a goat track.
http://vid135.photobucket.com/albums/q128/allan077/VID_20140821_105355_858.mp4
Drill cuttings bagged and tagged
http://vid135.photobucket.com/albums/q128/allan077/VID_20140821_103338_207.mp4
Diesel tank flown to number 4 shaft and my fitter was there in the truck and filled it.
http://vid135.photobucket.com/albums/q128/allan077/VID_20140821_102221_021.mp4
More Unleaded for the pumps, drill bits and important stuff like smokes :p
http://vid135.photobucket.com/albums/q128/allan077/VID_20140821_101051_913.mp4
Currently in PAD rehab
Can you bring me 2 racks of ribs and a carton of turkey 101 cans?
LED ZEPPELIN
1995 GQ TD42 NA
Biggest ****ing drone I ever saw!
Reactions: motomuzz
That is pretty cool. Is that the cicadas i can hear in the background?
Also, one of the most acceptable uses of the F word there in clear context. Lots of people exploit it but that was perfect
I may be wrong here, but I would have thought everyone in the 'drop zone' should be in hi-vis and have hard hats?
When a 2 tonne diesel tank lands on your head...your a busted grape. No amount of hard hats will save you. Also in the briefing between mines manager and the chopper guys..it was stated to us by the lift lads not to wear a hard hat as they fly off under the chopper blast and become projectiles. Last job they did in Sydney the blast hit a guy with a strapped helmet and near snapped his neck and he lost balance and broke hiss ass.
So sometimes some legislation made up in a office by a pen pusher just to justify his existence doesn't work in the real world.:) we had hi vis on only lad not too was the heli rigger. I don't know his reason for not wearing it.
Dronus that's just driller talk. Once upon a time I couldn't spell driller...now me is one.
In that first bid I can hear the noise you think is cicadas. Its winter and no signs of them as yet. In my opinion its his idler pulley bearing and I sent him the NtC bearing number last night along with the tensioner rebuild mod thread link :)
I played the video while i was sitting in the patrol and my engine blew up again. The head went that way and the guts went the other way. Im zuprised as the engine wasnt even running.
Ohh well gives me something to do today..
Car back in the shed..
Plus the dog has his stick...
My boy sits in the garage with me and chews the power leads that he can see and get to, the compressor leads are his favourite. He leaves the stick alone. Hmmmm maybe his mumma got it on with a rat?
Done.
Now for some testing.......
Discussion Starter · #12 ·
That was quick. What are you doing tomorrow? I have some soldering to do.......:) so where does this go inline? Before/ after jdvm?
All mounted and tested. Seems to clip at 3.88v. I am using a small 12v battery and there seems to be a slight difference from the power supply screen and my multimeter.
And here is a vid... i can do in higher res if needed..
Nissan Patrol fuel cut defender: http://youtu.be/rDkpWNz4Y7g
Next up.. put it after the jvdm..
just a good guy.
2009 gu ute
geez Andrew you have another day off. wish I was so lucky :coffeeti:
Whoops i was supposed to be putting those posts in the jvdm thread?
Pretty simple circuit really.
Im in two minds if it will go before or after. Im thinking after. That way you cant put a +ve variance on the 3.9v and give yourself limp again....
Gumby the gynecologist
1 - 19 of 19 Posts
