1 - 1 of 1 Posts
My Gregory's manual says when setting the timing on my petrol only carby TB42 @ 10degrees, the vacuum hose should be left in place on the advance unit. I was always under the impression that the vacuum hose should be removed when timing this type of engine. If I set it with the hose off, and then replace the hose the timing advances (naturally) about 5-6 degrees. I have done a search here but not found a conclusive answer. So which is it 10degrees at vacson or vacsoff?
Onyas.
1 - 1 of 1 Posts
