21 - 23 of 23 Posts
some chop mobs are authorised to install their own child anchor points, not to mention after market ones can be installed by altapac etc anyway.
i kept mine factory, i also gained some good space behind the seats but not chopping stupidly close to the seats.
keep ya rear wall vertical, guys that chop angles on them look friggen horrible.
Could the rear wall be constructed with child anchor points assuming the construction of the points complied with the applicable adr?
That's a question you need to ask your engineer. I know you can add them to a car that did not come with them standard, but they still need to be engineered. I was lucky I never asked the engineer before I cut and the first thing he looked for was the restraint bolt holes it was only by pure luck I cut 40mm behind the bolt locations
I did the same with my GQ.
Definitely best move i made.
Looking at fitting 2nd batt there now
Sent from my SM-A515F using Tapatalk
21 - 23 of 23 Posts
