sideways behind the rear seat. over to the drivers side as far as it will go.
it leaves enough room for a 60l waeco between the tank and the door.
if you need to lay the seats down you can still fit long items in, but only narrow ones.
you will need to mess about with the tank mounts. make the bands a single bolt not two bolt so it can go hard against the seat, and you'll need to make special mounts to bolt the tank clamps to the 2 different floor levels.
passengers side would be better for weight, but you have to open both doors to get at the fridge anyway and I have a draw for recovery gear that is deep, long and narrow on the passengers side that can be opened with the big door shut.
my storage draws are build up to the height of the top of the gas tank, leaving a large flat area in there when the fridge is out. My fridge is at floor level.
theres a few various pics in my photobucket.
