1 - 16 of 16 Posts
4x4
thinking of buying a winch, hoever, can anyone suggest where i could mount one should i buy.
also wondering if the bar is strong enough.
Need a better thread title. Far out. Winches are always mounted behind the bullbar and attached to the bullbar. Unless your a capitalist and have two then you mount one to the rear as well.
Rogue
nissan gu patrol
You can buy a winch cradle and cut a whole in the bar. Tigerz11 sell some cheap cradles.
I'm changing the thread title because it's a **** title that means nothing
Rogue
nissan gu patrol
Also, try and use the search function. There is a heap of threads regarding this already
Every dog has his day
2005 TD42 GUIV
So what was the old thread title???!!!!!
Reactions: Bekah
4x4
Discussion Starter #7
thanks to those who have helped.
Just a FYI, if my internet was not still in the dark ages in regards to speed, i would have searched but unfortunately they have no intention in the future to up our speed with the rest of the nation
Personally if it's an alloy bar I would use a proper alloy winch bar and a cradle supplied by the bar manufacturer so you don't have any problems. It's too late if you're in the bush and a standard alloy bar fails where the winch bar doesn't because it "may" have some extra reinforcing built in.
For the amount of messing around just get a factory steel bar. They can go pretty cheap, and if you live in Karratha the benefits of protection from an animal strikes are clear.
Pass the Popcorn
Nissan Datsun Patrol
Jff45 did a fantastic write up about it, was neat as they come! I'd post a link here but unfortunately all photos in said link have been removed. :(
Probably due to an altercation he had with a few mods a while ago. Shame really.
Thanks for your positive comment on the work I did.
There was no altercation with any moderator, in fact, I received supporting private messages from mods.
My mistake was in allowing myself to be ripped off by the principal Admin's best mate.
I was unjustly banned.
I tried my best to be a productive member of this forum with different illustrated threads I did.
I removed all images from my threads when I found out from a friend that I had been publicly branded a "Twit" by the forum administration.
Pass the Popcorn
Hi Jff45,
Don't mention it mate! It's good to hear from you again!
Yeah I did hear about it! Sorry to hear what you went through. Hopefully it's water under the bridge now and we can all move on!
Happy days 8)
Hope you come back mate, I know I''m not the only one that appreciated your threads.
1 - 16 of 16 Posts
