Hi guys, new to the forum but have been reading a lot of threads for research and what not,
Anywho I have a 2004 guiii patrol 3l, and it has been perfect, however a few weeks ago upon start up a bit of smoke started coming out - White smoke - and lasted probably 2 minutes, (very light white smoke) and the engine was nearly at running temp as I had been driving earlier. Anyways, it cleared up.
But now this after I started it up and it started fine, but little bit of
White smoke, and after about half a minute it idled roughy for about 5 seconds and cleared up, and the White smoke only on throttle, but I had no power loss, it was running normally, just that white smoke,
Which lasted for only about a minute this time.
Has me puzzled cause no one else has had this similar issue, a lot have had the White smoke,
But not quite this.
Any suggestions would be great on what it could be, I have been keeping close eye on coolant levels and oil levels, and they have been pretty good which means the coolant isn't disappearing nor is the oil? Thank you
And please no "shouldn't have bought a grenade, or "another pin pulled" ..
But not quite this.
