1 - 20 of 38 Posts
Took these this morning outside my office window when it pulled up to the Visitor Centre
Pretty sure it's not supposed to do that!!!
I'd say just came off the Gibb River Road poor bugger
Hello from Broome Marty.
Yer that isn't good and those corrugations are pretty bad this year. Need decent suspension and weight distribution because it been cut up bad this year.
P.s: Hope he had insurance
SAW Troll
Scotty
The Member Formerly Known as Lusty Dusty
Giday Marty, drove past you're fine establishment several times on the way to the jetty recently.
Will pop in and say giday next time I'm up.
Cheers.....Lionel.
Common fault with these tritons, seen a few now
common fault on a lot of utes. they are just not built to handle bad loading especially double cab. they see the '1 ton load rating" and go shove 1 ton behind the rear axle, beaf up the suspension causes its sagging its arse on the ground and wonder why the chassis breaks :rolleyes:
Wow. came across one at Mt Barnett three weeks ago - might even have been this one because the guy was trying to get someone to help him with chassis cracking...
Well it definitely broke the chassis
Left town on a truck
Fourth Triton this year out of the Broome office that's done the same thing
nissan gu
clearly this meets OHS laws for disability loading... now you can zip up there in your moto-scooter
:p
Here To Be Entertained
Currently not a vehicle owner
A jack under the bum, and a couple of ratchet straps over the top and around the b pillar and good to go.
Where have all the bush mechanics gone ?:(
Triton n Lovin it.
A couple of wheelie bars and springs and it will be right. ;)
Foo
Weekend Warrior
Nissan patrol
And a couple around the c pillars and the whole jalopy, skateboard steering.
NIssan
SAW Troll
Scotty
If the camper was not fitted correctly or was not suitable (weight or whatever) for the vehicle it was attached to then insurance would decline the claim.
I did see a Patrol ute once in similar condition (sans camper) when I had mine in for a warranty check. I dunno what they had done with it but it was a rather distinct banana bend in the middle
1986 SD33T SWB
Might want to chuck a screw or two from the floor of the camper into the roof to be sure, and chuck a couple of wraps of duct tape around the chassis to stop the bum end falling off.
There ya go, nice permanent fix.
Couple of zip ties and bobs your aunty ;)
1986 SD33T SWB
Ah yes, the old zip ties. Truly unbreakable :)
1 - 20 of 38 Posts
