1 - 20 of 34 Posts
As the topic suggests.... Why chop them when it doesn't increase departure angle?
Not only that but now you've gone and butcherd your beloved Patrol??
Thoughts?
imo it looks better than a dented up panel, if its not there its has to help with clearance in the rear.
Nissan patrol
It does help departure angle. just not straight out the back tho.
Also a rear bar can be made to sit where the old paneling used to be so there is no loss of clearance.
also, do it properly, dont go the rivets and silicone, like i have seen before.
4x4 Addiction
I just couldn't bring myself to chop mine.
They don't last long if you go offroad, once they dinted you will gladly chop them off.
I've owned a couple of shortys now and I've put them through hell. I'm still yet to punch in a rear quarter (touch wood)
Conquering tracks doesn't mean destroying your vehicle to do it.
They have a habit of rusting under the mudflap. Going to do mine soon for that reason alone.
Not only rusting, it's just a cheaper alternative to fix if it was damaged from 4wding. Looks different too on GQ Patrols, it gives that style of character to it.
Mine's a '91, been in NZ for at least 10 years, didn't even have mudflaps when i got it but no rust...
bit cold out it seems
no orifice intended but you do not drive hard if your quarters are un-touched.
4x4 Addiction
I always try to avoid panel damage but the lower quarters had multiple dints, this was the only section on my car that had dints, fixing them would have been a waste of time, so off they came.
A very old pic showing my lower 1/4 worst side.
Discussion Starter · #17 ·
Yeah i'm all for chopping them if they're stuffed. I just don't like cutting perfectly good panels.
Nice shorty by the way
Discussion Starter · #18 ·
Why should i have to stuff my quarters to drive fast? What about applying some ground appreciation? It doesn't mean you take more time to cover the same distance.
I drive slower than a nun and my GQ's quarters copped a flogging.
Mind you I had no choice when driving an atmo TD42.
I would say your idea of where you drive it is a fair bit different to some other's. And most likely those of us here in QLD with our sharp jagged rock spam. lol
Discussion Starter · #20 ·
Rock spam hey? haha..
Mine spends all it's time in the mud and snow, Vic high country mostly.
1 - 20 of 34 Posts
