Ok. What's the go .. I've picked up a 2nd hand 99Gu,rd28 gearbox .what ,if any differences are there to me fitting it to my 95Gq rd28 .. I'm getting the fly wheel n clutch with the box also .. any advice would be appreciated 😁😁
spent hundreds if not thousands trying to stop it running hot ???
well i have the answer for you and it is fairly cheap , no need for multi pass alloy radiators or anything like that , although i do recommend that all cooling system componants be in good running order
this fix is for most if...
Just starting a thread on turbos and the whys etc.
I come across a pic of the compressor housing brand aside but i have seen this before on some Chinese examples. Its to do with anti surge holes and slot position and where they should be positioned and why.
I will put up this pic to see who...
GU TD4.2t
I was away camping for a week and started to loose clutch at the pedal. It would pick up just off the floor. Clutch kit in it is relatively new. New master and slave. 3/4” slave bore.
This happened two years ago. Car has been sitting in the paddock since. I start and the clutch is...
Hey all,
I have a 2002 TB48. I rebuild the head last year. I didnt know you could put harder valves in (yes I asked, the head guy said nothing you can do) I am concerned I will burn them out again.
I have spent alot on getting th LPG running correct (injected Landi) , new mixer, rejectors...
