I had a towball fail on me once while doing a static load test on a towbar. Made a hole in a brick wall.Out on a limb here, I cannot see anything wrong with a recovery using a towball, as long as there is no big shock involved. Towballs cop heaps of forces when towing, just the massive forces that are involved in using snatch straps is the major problem.
OK, now what loads were applied in this static load test? There are trailers and there are trailers. My box trailer is a lot smaller and would apply a lot less stress than my 22’ caravan, and can be both towed with the 50mm towball.I had a towball fail on me once while doing a static load test on a towbar. Made a hole in a brick wall.
50mm tow balls should be used for one thing only… Towing a trailer.
Atleast the towball will remain captive in the trailer hitch if it were to break.OK, now what loads were applied in this static load test? There are trailers and there are trailers. My box trailer is a lot smaller and would apply a lot less stress than my 22’ caravan, and can be both towed with the 50mm towball.
I would never ‘snatch’ off a towball. Those forces are a bit brutal. But then again, a gentle forward movement shouldn’t cause any problems.
That’s a good point, but not the question that was posed. I’m not advocating using the towball, I’m just trying to sort truth from heresay. I know the forces that can be involved from an incorrect snatch are horrendous, but a steady pull is well within the capabilities of a towball. 🤔Atleast the towball will remain captive in the trailer hitch if it were to break.
I mean the hitch pin not the tow ball. CheersOut on a limb here, I cannot see anything wrong with a recovery using a towball, as long as there is no big shock involved. Towballs cop heaps of forces when towing, just the massive forces that are involved in using snatch straps is the major problem.
Static load test in accordance with AS4177.1 Appendix A.OK, now what loads were applied in this static load test? There are trailers and there are trailers. My box trailer is a lot smaller and would apply a lot less stress than my 22’ caravan, and can be both towed with the 50mm towball.
Was it the thread on the ball that gave way?Never got to 10 seconds and the ball came out the coupling.
That I know, am posing the question about the ball.I mean the hitch pin not the tow ball. Cheers
Sheared off at the mounting face where the shank starts. The tongue was bent so the ball wasn’t sitting on a flat face anymore.Was it the thread on the ball that gave way?
I think you are out on that limb by yourself.Out on a limb here, I cannot see anything wrong with a recovery using a towball, as long as there is no big shock involved. Towballs cop heaps of forces when towing, just the massive forces that are involved in using snatch straps is the major problem.
Some say that sticking the pin through the strap could potentially bend the pin, making it difficult / impossible to remove, and / or impossible to use for attaching a towing hitch ever again. I’ve never seen this personally.@AndrieK @geeyoutoo Does the use of a shackle receiver make any real difference to the way the load is applied to the hitch pin, and/or how much load it could withstand?
Or is it just an easier way to attach the strap/winch cable than trying to reach the hitch pin inside the receiver?
Seems to contradict. 🤔The other way id like to throw out there, is to just remove the Tow ball itself from the tongue, and use your large recovery bow shackle ,putting the shackle pin through the hole the tow ball normally goes through, this completely removes the tow ball from the equation, but does not risk bending the tongue retaining pin.
