1 - 2 of 2 Posts
2011 GU IV ZD30 CRD
Hi Patrol crew
I have a factory ss bullbar fitted to my 2011 GU. It's either part number: F2210-VD010AU (Wide Wheel) or F2210-VD210AU (Std Wheel) - don't know which, both numbers are on the label affixed to the bullbar.
I need to buy a winch tray, as it seems there is not enough structural support to safely bolt it. Which tray would you recommend?
The bolt pattern of the winch is: 254mm x 114.3mm
Any ideas?
Thank you
'14 Y61 ZD30 CRD M/T ST
Hi Patrol crew
Any ideas?
Thank you
The part numbers you quoted are late model wide body (ST & Ti) and narrow body (DX) steel bullbars, both of which are winch compatible. Not sure why you say they are stainless or why you think you need a "winch tray"...?
Can you post a pic of the bar?
There was only one stainless steel bullbar that was factory fitted (in Japan) but it was only available on very early GU's. This bar was compatible with a separate winch cradle.
All other "shiny" bars are locally developed Genuine Accessories manufactured for Nissan AUS by TJM from aluminium and are not winch compatible.
All black bullbars are also locally developed Genuine Accessories manufactured for Nissan AUS by ARB from powder coated mild steel and are all winch compatible. The winch bolts directly to the bar.
1 - 2 of 2 Posts
