1 - 2 of 2 Posts
Hi guys
due to cosmetic surgery on rust spots I have to take out the back windows. I'm going to tint them as the same time. Is there anything to talk care of/be careful with? (especially the seals) Try to avoid any potential problems.
cheers guys
Hi there, No, straightforward to take out. If you have sliding window on one/both sides, be prepared for rusty support frame inside the rubbers.... a bitch to weld.....
Straightforward to put back in again with someone pushing from the outside and a bit of cord around the rubber. Are you doing the tinting? Make sure you don't crimp the film under the window catch - it lifts after a while if it's under the catch support rubber....
1 - 2 of 2 Posts
