1 - 5 of 5 Posts
G'day all I've got a bit of a bug goin on my wipers and my lighter socket won't work unless I slam my door (not joking) or go over a large enough bump obviously something is loose but what is common between the two that isn't common to everything else????
Righto so I tested the fuses for power AND nope no power to all three fuses (front wiper, rear wiper and cigarette ) so I took the fuse Panel off only to find one main common power source for all three which is fairly large possible 6mm if not bigger and if I wiggle it the power flickers on and off which to me indicates that it's loose in the fuse connector part or a broken wire but being 6mm can't really see that being the case. My next question is how do I get the connector bits out from behind the fuse panel? Is there a little clip or something similar to hid plugs any idea would be helpful I'm sure
Good work
I'm no auto electrician
Shouldn't take much to work out how to fix it now
That wire should go to the Acc relay the middle relay on that panel by the wiring diagram
The next White/red looks like it joins in to the one in the corner
Good work finding those photos
1 - 5 of 5 Posts
