1 - 9 of 9 Posts
Hello
I have received my full function tail lights for my patrol. Got wiring all but sorted out. I have the following colours sorted
White/black stripe - earth
Green-indicator
Red/blue stripe- reverse
Just need to find out if park is black or green/white stripe??
Leaving the brake as the only wire left!
They are Depo brand and was asking info from members who have done installs themselves
Thanks
Daniel
Wiring solved
Hi Guys
Had a seniors moment just now and figured if I hook it up to a battery then I can figure the two wires in question. As per my previous post
The park light is the Green/white stripe and brake is black
Will add a photo of the wiring harness I used soon as I figure out how to.
NISSAN GU PATROL
I see a bit of exposed copper on that yellow wire, Better take care of that.
Not the best connectors but will do.
Yes I realised it was bare after I put the connector into the plug. I intend to get a tube of non conductive silicon type stuff and gill the back of each side if the loom to at least prevent any water issues should they ever arise,
Pass the Popcorn
Nissan Datsun Patrol
Hahaha.....Seniors moment, happens to us all! Glad to see you got it sorted.
And even managed to sort out the exposed wire
Just slid a piece if heat shrink up over each wire until it was just sitting inside the loom and whamo. All sorted. Now I've just hot to put them in.
Got the tight side all done but the reverse. Does anyone know the colour codes for the factory looms on he right hand side. Need colours for reverse, brake, Parkersburg and indicators please. Oh and earth to please
Thanks
Daniel
1 - 9 of 9 Posts
