1 - 20 of 43 Posts
So finally stepped up in the world 05 series 4 zd30. Pretty pleased , it's going to take some getting used to this lack of balls 4 cylinder bit, The old sd33t pulled from heaps lower in the rev range .
Sent from Alf Stewart's rape dungeon .
I'm impressed ;). ECU remap and a couple of other small mods will fix that issue :). So does this mean you'll want to change your moderation section? :rolleyes:.
I will do the the nads mods just to keep it all good , been trying to get the father in law to do all that stuff since he has owned it and then hopefully leave it be until I can sort a possible conversion.
Nah stuff moving about , to busy put side of my mod section, lol and just started building a red one up for my son's 1st car .
Yeah blacks a pain in the arse , but it looks so awesome .
Yeah
CRD Wagon
So finally stepped up in the world 05 series 4 zd30. Pretty please, it's going to take some getting used to this lack of balls 4 cylinder bit, The old sd33t pulled from heaps lower in the rev range .
Congrats on pulling the pin on a GU. Looks like a neat wagon too.
Small mods make a huge difference to the way the ZD drives. I am still in shock at the difference a big exhaust makes. It pulls sections of HWY OD locked that I used to have to press it down into 3rd OD off now.
Yeah dump , exhaust , cleaning the inlet , all things on the cards .
Datsun Patrol MQ 1982 RB25DE NEO
Shiny black looks great! Cannot wait to see it covered in mud :)
Pass the Popcorn
Nissan Datsun Patrol
Congratulations Paul....:cheers:
The upgrade has been a long time coming.
Reactions: Wish I Had Coils
1986 SD33T SWB
Congrats on the new wagon mate.
Discussion Starter · #11 ·
So had the GU for a few months , done bugger all to it , changed a few lights out for better ones , done the gear box and transfer case oils , changed the rear axle seal out and greased the axle bearing as the oil was all washed out .
So with a bit of piss farting around I ended up with a junkie needle, more commonly known as grease injection needle
I also bought a new coupler ,works a treat.
My latest job was a tillex and needle valve kit . Got one through Tillex , ordered it late at night 2 days later it rocked up . Very impressive .
So fitted this all up. And what a difference it's made, boost spike all but a psi spike here and there and much happier patrol off the mark or so it seems.
Now just waiting for my 3" exhaust to turn up , so I can fit a pyro gauge and hopefully should make a bit more difference and make the old 3 litre liveable and more fuel efficient .
LED ZEPPELIN
1995 GQ TD42 NA
Missed this somehow - congrats on the new wheels Paul.
You can get a ZD moving along nicely with the right mods.
Discussion Starter · #14 ·
Congrads mate.
I'm still trying to get my head around my grenade.
Not a bad little engine but its no TD....
Sent from my SM-N920I using Tapatalk
Cheers Boyd , yeah the Zd is a little different from the Sd33t or my brother td42t but hey this cost me a hell of a lot less then his Patrol, well so far anyway
Discussion Starter · #15 ·
Thanks Muzz , main thing for me is to try and get a bit of get up and go off the bottom end. So far the Tillix and needle valves have made a difference .
Really just want to make sure she keeps reliable until I'm ready for a conversion.
Discussion Starter · #16 ·
Forgot done the glow plugs , and I have a kemo timer ready to do the glow plug timer mod .
Should do it this lot of days off.
Black series 4's look so good.
Congrats dude hard work paid off i'm sure.
CRD Wagon
And look what just turned up
I'm interested to hear if you think it makes much of a difference. Initially I thought I'd keep the stock exhaust there if for some reason I'd wanted to change back - but no way in hell I'm going back.
your post reminded me to put it on scumtree today actually.
Ya better put it on Gumtree for "free to a good home" :) or top this one https://www.gumtree.com.au/s-ad/bal...sories/gu-patrol-2016-july-exhaust/1134201145
When I had my stock exhaust lying around I couldn't give it away - it went out on the hard rubbish, an no-one even scavenged it.....
1 - 20 of 43 Posts
