1 - 8 of 8 Posts
Hi
I finally converted my 4-speed to a 5-speed box. Had a new clutch installed as well. All forward gears seemed to go in. However, the stick just wouldn't budge into reverse. Not even when the engine was off. The box had the shift control unit off when I got it. I'm wondering if something is missing when we put it on the back. Or is it something worse? Any suggestions as to what it might be?
Update:
My mechanic pulled down the box on Saturday. Seems as if the previous owner had pulled down the box and hadn't put it back together properly. A couple of the shafts had been put in backways. He put it back together and tested the shifting on the ground. Seems ok so far. This weekend he'll put in back the gearbox and test it from there.
1 - 8 of 8 Posts
