1 - 5 of 5 Posts
Hi
I bought this Patrol new back in 2004.
Not many probs and very happy with it.
Went to use cruise the other night and did not work.
I can activate and it shows the word "CRUISE" on dash but then go to set and it does nothing.
Is this a common problem and where do I start to try to fix. Any ideas?
Thanks
Nick.
Hi
Yes , before you can engage CC the brake must be applied once as a self test. If there's no continuity ( blown bulb) the test fails. CC
will flash.but not function.
Also check hidden fuses inside ABS controller.
Sent from my SM-N960F using Tapatalk
1 - 5 of 5 Posts
