1 - 20 of 37 Posts
Ok so my new Patrol is here ST-L and I am wondering how to tell when its in 2WD and if there is a way to lock the rear diff when in 2WD? Yes I would like to have a little fun with it on the beach and on the back roads.....
Cheers Josh
It is constant. 4wd. I do notice it will spin up(very little) the rears if provoked but no "fun" like a commodore.
According to the Middle East guys pull these 2 fuses and you will have 2wd, it's the only way to get just 2wd that I know of. In auto mode trying to spin just the rears normally the front wheels kick in and end up pulling you straight or in the direction your wheels are pointed. I've found on the sand and mud etc it's easier to engage 4 low and all 4 spin can tell you it's a lot of fun ;) got the power to do it
Hmm interesting... yes I am looking forward to lighting up all fours! But also can't help but think that I will also want to do some donuts on the beach with the V8 it's is going to be impossible not to be a hook.....:D
Yeah i found out first hand how much fun you can have on the gravel, still felt like a rwd biased 4x4 system as it was quite taily still.
After reading the book last night it does run 2wd or 4wd in auto page 5-18 if your bored like I was....
It's rwd until it senses a loss of traction then it will send power to the front aswell, not keen on it as it's abit unpredictable
You can switch to 4wd high mode. Believe this locks centre diff to allow 50:50
Yeah I see now that some guys have a ABS of switch I assume that it is for the 2wd. Might be an option and a hard wired switch to the diff itself for locking in 2wd.
Nissan Y62 2013
It's constant 4wd with 75% in the rear wheels and 25% in the front, when you engage 4H or 4L it becomes 50:50
About the method shown in the pic above It's the way to do it but I DO NOT RECCOMEND doing it because it has a lot of power and flipping over gets easier when you just have 2wd.
I've tried leaving it in 2wd for about a month with just removing the Red #10 fuse shown in the pic, the pink one is the ABS, It was fun when going around corners ;) did a little drifting etc. , but as I said... lots of power.. DO NOT TRY IT if your not a capable driver.
I have an ABS off switch so that I can actually stop on steep and slippery inclines, where and when I want to stop and not when ABS decides. Also, when I engage the ABS off switch, it automatically selects 4 HI and cancels out the terrain [traction control] selection.
Discussion Starter · #15 ·
ok so i pulled the above said 4WD fuse and just pressed the console T/C button to turn it off and yes as it is very wet over here in Perth today it was a good test. i can confirm that round-abouts are very fun.... I think i will be installing a switch somewhere for this fuse note tho that the car has to be turned of and re-started to clear the 4WD caution light. But for those that do want to have fun on the beach or gravel roads!:D
Nissan Patrol Y62
Found a neat little adaptor on eBay that made putting in a 2wd switch quite easy. Top right yellow and green wires. If it ever has to go back to Nissan it would be easy to remove and put the fuse back in. I think it was about 9 bucks plus delivery. In line fuse is now located near in cabin fuses.
Not sure what Nissan would think about the extra fuse box and extra wires though? Should really neaten them up I suppose.
Sweet Jesus that is some pathetic control of ones vehicle!!
And some wicked abuse of the engine! Lol
1 - 20 of 37 Posts
