1 - 2 of 2 Posts
Hi all Am looking for anyone that can let me know what I can do or if anyone has had the same problem with there zd30 with just cutting out of power and going to limp mod then you have to take the foot of the pedal and replace it again to get back power . have had it for a while. have closed off the vanes just 3 turns on adjustment on the turbo witch I has stopped it for now . but am wondering if any other people have found a way around this problem with out closing the vane off on the turbo. hope you can help if not all the best and safe . take care :confused:
There is alot of threads already on this particular problem.
The best solution, well the cheapest one is to fit a dawes and needle valve (set the vanes back to where they need to be)
Replace your air flow meter straight away if your not sure when it was changed last.
You get the limp mode if the boost exceeded 15psi below 3000rpm for about 5 seconds.
Do you have a boost gauge?
1 - 2 of 2 Posts
