1 - 19 of 19 Posts
Rogue
nissan gu patrol
I have two ZD30s. UniChip (or Safari/DpChip) are the better for the DI. I have one that is untuned and it still goes fantastic. I also have a custom 3" exhaust that cost $700 and a Scott Rods that cost $800 and I'd certainly shop around for a custom build as the Scott Rods is ****.
nissan 4.5
Aint nothing wrong with my scotts rods
How much power difference does it make?
Forget all this Hp is everything crap, it's not everything, driveability is what counts, my 2-3/4" Beaudesert changed the whole face of the vehicle. Bits I had to drive in 4th were now drivable in 5th and it only got better :). They are expensive and not for everyone but like my CCIC, I'd do it again in a flash. To each his own.
We have just brought a 23 ft caravan looking for torque to tow with
That's what your after, I'd gladly give up a few ponies for a few more Ft/Lb torque down low, this is what I have been working on for years, my max HP is at 3700rpm, bugga I very rarely get there but if I can pull away from 1200 in 4th (especially with a bloody solid flywheel) in a ZD30 I'm as happy as a pig in mud.
Nissan patrol
Discussion Starter #13
And that's with a 2 3/4 inch exhaust . I have standard one on my car looks like I will be changing. So is a 3 inch not as good
No, not saying that, but I can give you 3 examples of similar ZD30DI, one with a 2-1/2" another with a 2-3/4" (mine) and another with a 3", the torque outputs, although similar in Ft/Lb, came in lower in that same order, interesting, not scientifically accurate/proven but interesting. Personally I feel the 3" is more suited to the CRD and the 2-3/4" the DI as an overall call.
What I have striven for with my DI is not outright Hp, I don't care if it's 160 or 140hp, what I targeted and achieved is the ability to get lazy in 5th gear on a winding 60k road and leave it in 5th, done. I pull a 5.5m boat (and not often enough) an off road camper, so all this helps that.
My 2 cents worth :).
Proof is in there. Towing a 5.5m and a off road camper at the same time.
You have sold me on a 3" exhaust and unichip Gee :driving::driving::driving:
1 - 19 of 19 Posts
