As the title states my 3ltr is coming up on 300,000km now and will need a service i plan on stripping off the turbo, intercooler, exhaust and intake manafolds and cleaning them all out. also replacing glow plugs, coolant, all the oils and so forth.. just wondering what else i may need to look into when doing the service? timing chain?
Buy a young goat and sacrifice it to the gods to appease them. Keep that good luck going.
Go Hard or Go Home
How about Disc rotors & brake pads, possible new belt tensioner, MAF, Injectors.
New seal kit for the turbo & possible service on the IP. Possibly get the head checked for shim wear/adjustment for the valves.
Timing chain....why not if you plan on keeping it, I would.
I wouldn't be touching turbo, injector pump or injectors, unless I had a problem with them.
Head????????????
Brake pads and rotors, just the same.
Do a normal service ie. fluids and filters, grease uni joints and bearings.
Cleaning air intake could have it's benefits
