ZD30 CRD Oil Guide
1 reading
37K views 41 replies 13 participants last post by  Jordan1986
I have found that when looking at oil company web sites, their recommendation for ZD30 engine oil differs between the early ZD30 engines and the 2007 – 2011 model CRD engine. Is this a marketing ploy or does it have merit?
Anyway, it is for this reason that I thought it might be a good idea to have a thread dedicated to engine oil options for the CRD ZD30.
Inspired by whitie’s thread Oil's ain't Oil's I decided to look at what makes an engine oil suitable for the CRD ZD30. Here goes.
As has been discussed the Nissan service book calls for a CF, B3 or JASO DH-1 spec oil and states that a 5W-30 oil is recommended or chose from the SAE table. What does all this mean and is this information current.
For info see the following links:
API SAE Motor Oil Guide 2010
http://www.api.org/certifications/engineoil/categories/upload/MOTOR_OIL_GUIDE_2010_120210.pdf
JASO list of DH-1 oils
http://www.jalos.or.jp/onfile/pdf/DEO_EV_LIST.pdf
DH-1 is the classification used for light duty passenger car four stroke diesel engines and is allowed to be used for diesel fuel having more than 0.05% sulfur content.
Note: Delo 400 does not appear on the current revision list. (Delo 400 was on the last revision and by all accounts is an excellent CI-4 oil at a great price).
ACEA
http://www.acea.be/images/uploads/files/2010_ACEA_Oil_Sequences.pdf
Ok first up, I use BP Ultimate.
http://www.bp.com/liveassets/bp_internet/australia/corporate_australia/STAGING/local_assets/downloads_pdfs/d/BP_Ultimate_Diesel.pdf
BP Ultimate has a Cetane rating of 46 min and typically 52. (Cetane is to diesel as octane is to petrol engines). My Nissan service book says to use a min Cetane rating of 51. BP Ultimate is the best spec I can find.
Secondly, note the Sulfur content of BP Ultimate at min 10 mg/kg and typically 5 mg/kg. This has a bearing on what oil spec is appropriate.
10 mg/kg = 10 ppm = 0.001% and 5 mg/kg = 5 ppm = 0.0005% respectively.
Armed with the above information let us look at the oil specifications.
The API CF rating is now obsolete. Introduced in 1994. For off-road, indirect-injected and other diesel engines including those using fuel with over 0.5% weight sulfur. (BP Ultimate is now rated at 0.001% weight sulfur).
CI-4 was introduced in 2002. For high-speed, four-stroke engines designed to meet 2004 exhaust emission standards implemented in 2002. CI-4 oils are formulated to sustain engine durability where exhaust gas recirculation (EGR) is used and are intended for use with diesel fuels ranging in sulfur content up to 0.5% weight.
Next is the ACEA standard. B3 is a light duty diesel oil spec and is recommended for severe driving conditions. The B4 is suitable for direct injection diesels and the B5 for extended drain intervals.
Basically it comes down to choosing oil that meets the CI-4 API standard and at least a ACEA B4. As Chaz said in another post the SAE oil viscosity number is a basic indicator and a more accurate way to compare engine oils would be to look at the oil characteristics, namely the cSt at 40 deg C and at 100 deg C.
When I get the time I will put together a list of oils recommended by the oil companies and table their specifications.
I am keen to learn more so feel free to correct or add to this post at any time.
Steve.
#3 ·
Good point Chaz,
Blocking the EGR cuts down on the carbon that makes its way into the oil. CI-4 oils were developed to handle the added carbon and deposits of EGR systems. The carbon deposits are held in suspension by the oil and circulate through the oil system. I have been told that this carbon acts like a mild abrasive ( in a good way ) that helps to keep clean the bores and other internal engine components.
If blocking the EGR system I would definitely extend the drain interval beyond the commonly accepted 5000 km oil change. Just because the oil looks black and dirty does not necessarily mean that it has had it.
Thanks for your feed back Chaz and I welcome anything you have to add to increase our understanding of crank case oils.
Regards,
Steve.
#4 ·
Typical Characteristics
Havoline Synthetic Blend
SAE Viscosity Grade 10W-40
KV @ 100 Deg C (cSt) 14.5
KV @ 40 Deg C (cSt) 99.5
Viscosity Index, ASTM D 2270 151
Density @ 15 Deg C kg/L 0.896
Total Base #, mg KOH/g, ASTM D 2896 8
Pour Point, Deg C, ASTM D 97 -30
Phosphorus Max % 0.14
Sulphated Ash 1.1
Industry Specifications CF, B3-04, B4-04
Cold Cranking Viscosity, cP @ -30 Deg C
Mobil 1
SAE Viscosity Grade 5W-50
KV @ 100 Deg C (cSt) 17.5
KV @ 40 Deg C (cSt) 108
Viscosity Index, ASTM D 2270 180
Density @ 15 Deg C kg/L 0.85 (@ 15.6 Deg C ASTM D4052)
Total Base #, mg KOH/g, ASTM D 2896 8 11.8
Sulphated Ash 1.3
Industry Specifications B3, B4
Nulon Full Synthetic
KV @ 100 Deg C (cSt) 14.8
KV @ 40 Deg C (cSt) 98
Viscosity Index, ASTM D 2270 152
Density @ 15 Deg C kg/L 0.865
Total Base #, mg KOH/g, ASTM D 2896 8 7.2
Pour Point, Deg C, ASTM D 97 -2.7
Phosphorus Max % 0.098
Sulphated Ash
Penrite HPR Diesel 5
SAE Viscosity Grade 5W-40
KV @ 100 Deg C (cSt) 14.6
Viscosity Index, ASTM D 2270 153
Density @ 15 Deg C kg/L 0.861
Total Base #, mg KOH/g, ASTM D 2896 8 11.9
Phosphorus Max % 0.101
Sulphated Ash 1.23
Industry Specifications CI-4, B4
Cold Cranking Viscosity, cP @ -30 Deg C 5934
Shell Helix Ultra
SAE Viscosity Grade 5W=40
KV @ 40 Deg C (cSt)
Phosphorus Max %
Sulphated Ash
Valvoline Durablend
KV @ 40 Deg C (cSt)
Phosphorus Max %
Sulphated Ash
Valvoline Synpower
KV @ 40 Deg C (cSt)
Phosphorus Max %
Sulphated Ash
Delo 400 Multigrade
SAE Viscosity Grade 15W-40
KV @ 100 Deg C (cSt) 15.1
KV @ 40 Deg C (cSt) 125
Viscosity Index, ASTM D 2270 125
Density @ 15 Deg C kg/L 0.886
Total Base #, mg KOH/g, ASTM D 2896 8 12.2
Pour Point, Deg C, ASTM D 97 -33
Phosphorus Max %
Sulphated Ash 1.4
Industry Specifications CI-4, CI-4 plus, CF-4,CF, JASO DH-1, E7
#34 · (Edited)
Sulphated Ash 1.1
Mobil 1
Sulphated Ash 1.3
Sulphated Ash
Sulphated Ash 1.23
Shell Helix Ultra
KV @ 40 Deg C (cSt)
Phosphorus Max %
Sulphated Ash
Valvoline Durablend
KV @ 40 Deg C (cSt)
Phosphorus Max %
Sulphated Ash
Valvoline Synpower
KV @ 40 Deg C (cSt)
Phosphorus Max %
Sulphated Ash
Delo 400 Multigrade
Phosphorus Max %
Sulphated Ash 1.4
Great thread. A lot to digest. Thank you all for the info. I just bought a 2010 zd30crdi, 200k klm, fully kitted with NADS. Is this list still a good guide in 2021?
#5 ·
I had a table to upload but due to the size I was unable to post it. If anyone can help me out uploading the table please PM me.
I added the Delo 400 Multigrade to the list as a reference. It is not listed as a recommended oil for the ZD30 CRD in any of the oil company's lub guides but as has previously been mentioned is a great CI-4 oil.
If you have any updates or additions please add to the list.
If you have used any of these oils it would be great to hear of your experience and recommendations.
Steve.
#6 ·
Good info Steve. I have been using Mobil1 5W50 for quite a few years in my ZD30 Patrol at 10K intervals and couldn’t say a negative thing about it.
Personally, I’d prefer a blend with a 40c cSt closer to 100 and 100c cSt closer to 20, so I’ll be switching to Penrite SIN 0W50 at the next change with a cSt at 40c of 108 and 100c at 18.7.
#7 ·
ZD30 oil
Hello Chaz. I'm Jay from the Philippines. I just ask wanna you if the Mobil1 5W50 you are using is a synthetic blend. Tnx.
#16 ·
Just for a bit of light reading see link to the revised JASO Automotive Diesel Engine Oil Standard.
http://www.jalos.or.jp/onfile/pdf/DH_E1205.pdf
The Nissan Patrol ZD30 owners manual lists the JASO DH-1 oil specification as suitable for our engines. DH-1 classification is designed for "D" diesel engines with long term exhaust emission regulations.
There are two additional JASO diesel oil classifications, DH-2 ("D" diesel "H" heavy duty truck bus) and DL-1("D" diesel "L" light duty passenger car) which are recommended for engines with Diesel Particulate Filters DPF.
The major difference between the DH-1 and DH-2 / DL-1 classifications that I can see is with reference to the limit placed on the phosphorous content. The DH-2 and DL-1 have a max phosphorous limit but the DH-1 does not.
I think that phosphorous is an anti wear additive but has a detrimental effect on the catalytic converter. Hence the recommendation for a DH-1 oil for the ZD30 in the Patrol.
It is hard to find an oil sold in Australia with a DH-1 certificaiton but we can use the specifications in the document to help choose oils that would meet the DH-1 classification.
#20 ·
What oil should I use in my ... is one of the most frequently asked questions on this forum and the simplest answer is as per the major oil companies on line lube guides. This is based on the requirement of the engine manufacture. For the GU ZD engine that is: API CE, CF, CF-4 or JASO DH-1. For viscosity number refer to the SAE chart.
The primary purpose of engine oil is to remove heat. It does this by flowing through the engine picking up heat and transferring this heat to the sump / oil pan for dissipation.
If the oil is too thick it will not flow at the optimal rate and therefore spend too long in the hot section causing a hotter operating engine and heat stress on the oil.
Once the oil reaches a temp of around 130 deg C it starts to break down or denature.
The second priority of engine oil is to lubricate. It does this by providing a thin film of oil on moving parts to form a barrier or slip surface to lessen the effects of friction. Additives such as phosphorus and zinc etc are added to improve and aid this lubricating barrier.
Now, to comply with environmental targets, engine manufactures fit EGR, Catalytic converters and DPF’s. (Note the ZD engines fitted to our Patrols don’t have DPF’s). To prevent the rapid deterioration of the Cat and DPF’s and to reduce emissions the oil companies have to remove or reduce the amount of additives.
The link at post #17 above talks about the reduction of additives in the latest and greatest oils as the oil companies modify their oils to comply with the latest emission standards. If you use a higher spec “latest and greatest oil” in your engine you may be paying a premium to kill your engine with kindness.
Engine manufactures have taken all of the above into consideration and specify the SAE viscosity rating and oil grade accordingly.
The Nissan workshop manual “Supplement for Australia” dated Sep 2007 in the MA Recommended Fluids and Lubricants lists API CE, CF or CF-4 and JASO DH-1* for the ZD engine. *For further details, see SAE Viscosity Number.
So the two things you may consider when choosing engine oil are:
1. SAE viscosity rating for the climate you are operating in and ;
2. The oil class or grade.
I am now using Delo 400 “Multigrade” 15W-40 and carry out oil and filter changes at the maintenance interval for severe driving conditions of 7500 kms.
As always if you see an error in my post or have additional info feel free to add.
Steve.
#25 ·
Thank you for the informative post
I have been finding it hard to get my head around why its better to have a higher number at cSt @100 deg C, when the preferable number is in the early teens.
But I think I have it now.
Please feel free to tell me if i am wrong.
I was under the impression that the higher the cSt meant more restriction in the oil.
I assume the engine has a tolerance for the cSt at 100 deg c
I think the lower preferred (manufacture) cSt@100 number it at the bottom end of the tolerance. As the lower number may produce better fuel consumption and lower emission?, But the higher the number may be better on lubrication but not as good on emission and fuel consumption.?
#26 ·
Hi yrrab,
Yes the higher the um (micro meter) number the greater the wear.
The ASF unit is beyond my level of knowledge so I will leave that to the more learned on this forum.
cST Centistikes is a measure of oil viscosity. Engine oil data sheets give us cSt @ 40 deg C and 100 deg C as this provides the rough temp range of the engine oil.
For more info see
Viscosity
In your last post you are correct in your understanding of the effects in changes to the cSt @ 100deg C has on fuel consumption but engine wear and oil degradation would be a factor.
What engine do you have in your Patrol?
Steve
#28 ·
Old thread I know, but thought of putting it here than in a new thread.
I also noticed in my Owner's Manual the oil spec says it needs to be API OR JASO DH-1
And the following link is the only one I found specify oil grade/type based on the series number and it suggests 15W-40 for my 2012 CRD.
Peak Lube Guide | PEAK OIL
#29 ·
OK, a bit further reading if you have the time:
http://www.widman.biz/uploads/Corvair_oil.pdf
And after reading through several information online I come to the following conclusion:
Always select the grade as per the manufacturer
BUT... giving the following important consideration:
comparison of cST from SAE for the given grade
Just a bit of explanation on this regard;
1. The design and manufacturing of the motor never going to be understand by a consumer. So here I am happy to assume Nissan is correct in specifying the correct grade for the motor.
2. This does not mean to buy OEM oils. All it is required to do is to compare the oil market to suit what Nissan specified.
From these this is what I have decided:
1. for 5W-30 (Nissan spec) the oil need to fulfill the following (happen to find one on the internet)
http://www.oilandenergy.com.au/wp-content/uploads/2016/06/SAE-Chart-768x576.png
From this table I need to make sure the oil I am selecting for the motor is meeting the criteria.
So far I have used Penrite 5W-40 HPR5 Diesel but from the spec id does not meet this criteria from the Manufacturer.
So now I am changing my oil to meet these specific criteria and may be going to go with full synthetic as well.
Disclaimer:
This is only my decision and may not reflect a true or correct reflection of engineering background and I do not take any responsibility for the any damage caused because of your decision based on the above information.
#32 ·
Digging this one up once again. I know there are many different oils which will work some better than others. Just want to share my experience.
Just purchased my 2011 CRD and about to flush and use Nulon 5W30 long life Diesel (SYND5W30), I used this in my 2000 Landrover D2 Td5 and instantly received and extra 50-90 km out of a full tank of fuel (95l) over whatever oil was in the engine at the time. Only used that oil from then on in and held up great over the time I had the vehicle which included a trip around Australia and living in Mt Isa for a year. Engine was smooth and oil had consistent performance from start to finish of its 7500km cycle, probably would have been fine to extend the change out to 10k.
The rating that matches the ZD30 is API CF. You can search by oil spec on the Nulon website which is handy. I have also confirmed with Nulon it will be fine to put in the Patrol.
Ill post my findings in here when its done maybe it will help someone else.
