Hello I need some help I have a 2001 gu patrol 380k on the clock awesome zd30 shame their a grenade
problem all was going aok until the hydraulic tensioner faulted it failed and started loosing oil in the hydraulic oil part of it (a small tiny rock on one of the groves that the belt goes one), ok after a few phone calls found out if it does fail id be stuck on the side of the road so limped home
started it the next day and oh it was making a bad noise very bad, I ordered a new one hydraulic tensioner and got ripped of by burson's I found out later cause the part cost me $350+ not including installation (only option as out in the bush) they exploit everyone those maggots but no choice what do you do
ok done and dusted replaced it
started it up
another noise had developed sound's like the timing chain slapping the plastic sleeve (had mechanic a look at it he said timing chain as well kinda confirmed my thinking)- ok ordered kit pulled engine apart and replaced it put everything back together again started it up grrrrr fme the same sound is there coming from the front of the engine right where the chain is sounding like the chains slapping the plastic guide so pull it part and check it just in case nope all good after 5 mins the noise goes away so still investigating it
ok the real reason for this post is I have spent probably 40 hours looking through this forum to no avail spend over a week googling etc my issue cannot find anything similar t0 my fault and rand Nissan they cant explain it contacted many diesel mechanics they cant explain it
my fault - I now have exhaust coming out the air filter/snorkel and not much exhaust coming out the actual exhaust however I have removed all the exhaust from the turbo to the back and its not blocked im only getting small amount out of the turbo
any ideas would be appreciated
started it up
