Bush and Beach-Bum
Hi guys!
I'm looking for a way to shut down a ZD30 engine reliably and fast. (via kill-switch in case of roll-over etc.)
This is a competition-only vehicle, so legality is irrelevant.
I know my TD42 has a fuel cut-off solinoid, if I interrupt that wire, it shut's down.
But given that the ZD30 has a computer and electronic injection, what's the easiest way?
Is there a wire that I can switch, which will shut it down?
I would appreciate any help as I have no idea where to look.
I recommend hooking up a roll over kill switch off the oil pressure switch, just in case your knocked out cold.
No idea about the best method of hot wiring though.
if in doubt turn off power to ecu. to inject fuel it fires a solenoid, no power means no injection.
Bush and Beach-Bum
Yeah that's a thing I've also thought of but I'd be buggered to find which wire I can tap into to do that easily.....
hi i need help , i noticed your reply to someone one the forum about the zd30 motor , i have a rough shutoff when turning the vechile off. my zd30 my swirl port valve control accuator is not working , please help me if you can , hade this issue for a long time . im at 330000 km atm.
what long term damage can this cause ?
any info will be much appreacited !!!!,
kind regaurds ,
lewis
