So I just got the NATS finally sorted out on my zd30 patrol and now I’m having issues with the injection pump. It cranks over but won’t fire. It seems like the injection pump is not making pressure for some reason. When I crack the injectior lines and crank the engine over the fuel only drizzles out. I would assume it should squirt out at very high pressure. The fuel primer also doesn’t stay hard when I pump it. there is fuel going to the pump and the primer is working because fuel comes out when I take the hose off to the pump and pump it. fuel comes out the return line when cranking. I’ve checked all the glow plugs and they all work fine. Fuses and relays are all fine. Not sure what the issue is and if it is the injection Pump then I want to be 100% sure. Any help would be appreciated
