Hi guys,
I have recently purchased a 2000 GU II ZD30 intercooled.
It has a 3" exhaust, SW chip, dawes valve and needle valve setup as well as a blocked EGR.
I've set up the dawes valve tonight and took it for a spin and it'll boost up to 19-20 psi and it pulls like a freight train. The only downside is 5 seconds later car is in limp mode.
Now my question is what is the max safe boost that can be run? I know of the anti limp devices out there but wonder if they are worth it. Is running 20 psi under acceleration ok or will this be too much to handle for the engine? If that is an acceptable level of boost I'll turn my attention to such a device.
Also what is the maximum EGT one would want to see? I'm new to the whole diesel thing and with the reputation of ZD30 in the back of my mind I'd love to know what is safe and what should ring alarm bells?
Thanks in advance.
Thanks in advance.
