HI,
i own ZD30 2001 model and i have the opportunity to buy a CRD (2008 ) that got off the road due to an accident,
i would like to take the ZD30 body and put it on the CRD chassis (with the full power train, axles and etc.)
can you guys help me understand what this exchange will required from me?
are the body mounts will be a perfect fit or i will need to adjust it?
will i need to use the CRD electric Power strip or can i use the ZD electric Power strip?
if i will need to replace the electric power strip, is it complicated (will i need to cut and weld wires or its just a bolt on?
are there any other issues that i need to expect?
Thanks for your help
