Ok looking to get some info on a 2 inch lift before spending my $$$.
1. 2inch shocks are the same length fully extended as genuine Nissan shocks,
Does this mean if I fit spring spacers with standard springs it will allow me to run a longer shock and still keep springs captive?
Assuming 2inch shocks are same length, this would make 3inch shocks 1inch longer and 4 inch shocks 2inch longer than original.
This would mean I could run 4 inch shocks and springs would remain captive???
2. If this is the case, would the shocks be operating outside there design range?
I have currently fitted 2inch spring spacers because to be honest I quite like the ride of the standard springs and in the past I have found aftermarket springs to be a stiffer ride.
Since fitting spring spacers I have noticed the ride being alot stiffer, I'm putting this down to the shocks not working in there normal design range.
Looking at amarda extremes so I want all the right info before I buy.
