Hey fella's,
Can you access the fuel tank (the top of) from inside the back cargo area/under seat?
LWB wagon? For inspection, or to check the lines or say remove the sender unit. Its a Long Ranger aftermarket tank, with no "apparent" holes ....
I filled the tank- it squirted out the filler neck as it does
then started running from the top of the tank, onto the floor. Gave the servo lady a heart attack! Spill kit Witches hats- nearly the fireys. Lost maybe 2 litres, and the fuel gauge is reading half. Its been reading empty for 2 weeks as I use gas 90% of the time. Just use petrol for starts.
You know the drill.
Thanks !
Mark
You know the drill.
Thanks !
Mark
