adjusterble drag link or remove and straighten steering wheel
1 reading
3.8K views 8 replies 7 participants last post by  streeter
can i remove the steering wheel on my 2010 gu patrol and staighten it or do i need and adjusterble drag link? ive got a 3inch lift.
#2 ·
You need to get an adjustable drag link because you've compromised the lock to lock angle of the steering box. Essentially to go straight with the lift, your pitman arm on the steering box is turning left. Putting on an adjustable link will allow the pitman arm to return to it's normal spot.
Plus it's easier to install a new drag link than frig around with the airbag, etc.
#5 ·
Drag link from road runner is the only way to go! They are the cheapest yet best made for the task I shopped for ages and found there was the one to buy whether you go the solid or just hd.
What I would love to see is a company produce a hi steer mount/plate/bracket on the steepening knuckle to eliminate the angles imposed on the drag link once you lift the patrols.
