gday all, today i put on my new bunnings flares to give more clearence around my 33" bighorns, and extended them a little, to put the tyre back under the flares, as they stuck out of the factory ones.
materials:
and then use a nicho to mark out you cut outs, and then remove, and cut, then screw back up to see how it looks, mine looked like this from the inside of the flare
then, when you are satisfied, upull off your template, and cut 2 more outa the roll of edging, ans use your template to mark it out, and put all the same screw holes in it (remember to be carefull with the good ones, dont wana scratch them...lol)
And rember to flip the template over to do the other sie of the car, otherwise, the flare will be either backwards, or the other side up.
finaly after you have done the same for both front (and simply repeat the process for the rear flares aswell, screw them all in and the finished product should look like this
then, head out to your local flex ramp (woolies car park for me) and test them out, like this.
in the last pic, i am aprox 5MM off bumpstop, not sure of how much droop is left on other side, with no lift, and my 33"Bighorns on. very very happy with that.
cheers for reading all
enjoy
jbates58
materials:
- Lawn Edging from bunnings (100MM X 10M) - around $45
- Aviation Snips or Tin Snips
- box of metal self tapping TEK screws
- Drill
- Nicho
enjoy
jbates58
