how much oil should go in a H233 front diff and a H260 rear diff.
When the rear was drained it was filled to the filler bung so all i need is confirmation this is correct.
The front was about 1-1.5 inch below the filler, i was told this is probably the correct amount as the filler is higher than required. I was also told if i put too much in it will drain out the axles seals. Can anyone confirm this???
