Hi Guys,
After some advice regarding an issue i have with my Fan and Aircon in my GQ, From what i can tell where the (Fan housing?) is located above the passenger footwell it seems this is made up of two parts with a foam spacer in between?
i have two issues one the foam has decided to fall apart so the fan makes a horrible noise when running and also most if not all the air comes out in the footwell as there is a gap present. Has anyone had this issue as well? not sure where i would get a replacement part or if i could even just purchase one from the wreckers without buying the whole system.
Second issue i'm having is my aircon is not working.. from what i can tell the Aircon compressor is not engaging when the button is pressed. i have checked the clutch on the pully and it is free so i don't believe it's the clutch causing the issue more a power issue. trying to figure out the wiring i need to look at to check it's getting power.
Thanks in advance for any advice.
