Hi all, this fuel issue is driving me crazy. The old faithful is struggling to run thanks to air in the fuel lines.
When i go to start the rig, it starts first go no worries. But then after about 1 or 2 minutes of running the revs begin to die and it starts wanting to stall. If i bring the revs up manually it will keep running but it wont idle. if it manages to stall it wont start again until i prime it, and then the engine fires and runs alright. Sometimes i need to prime for ages other times only little bits. Other times if i just keep the revs around 1200 or higher for a while the air comes out of the system. It splutters a bit but it eventually bleeds all the air out.
I have just had the injector pump replaced proffessionally, new injectors, new injector lines, new spill rail, new washers in all parts of the fuel system, i have installed all new soft fuel lines, new hand primer pump, new fuel filter.. there are no visible fue leaks anywhere when turned off.
I tried the clear fuel line trick, deffinatley air coming up. From where i have no ****ing clue. Any ideae?
