Shift lock on 04 Nissan Pulsar
1 reading
6.5K views 8 replies 6 participants last post by  Mic
The missus 04 1.8l Nissan Pulsar is giving me the s*#ts. It's an Auto and with foot on brake and car running I am unable to get it out of Park with out pressing the shiftlock switch on the trans.
I have pulled it all apart and can't work out what is stopping the little plastic tab from getting the f out of the way to let me change out of Park. I have changed the brake light/shiftlock switch/ignition inhibitor? (assume that is what the other set of contacts is for as the brake lights work and Haynes manual says nothing about this switch) on the brake pedal as that was stuffed and replace the ignition inhibitor relay for good measure and bloody thing still not fixed. Worked once then not again. I have played with the tension on the cable that runs from the shifter button to the ignition still no good.
Maybe the actual shifter is stuffed but 800 bucks is a bit rich.
Does anybody have any ideas as to what could be the cause?
#3 ·
on the mitsubishis that used to have this problem with there was small micro switch on the shifter that also used to die. dunno if these have the same setup though.
otherwise check that the actuator is getting power to it and also see if you can find an earth with a multimeter. make sure this hasnt got a high resistance.
im still struggling a bit to realise if you did actually replace the brake light switch or not but it not just bridge the plug with a paper clip or similar and try again. sounds weird but its possible.
#4 ·
If its anything like the auto shifter setup that i removed from my skyline, i just removed the cable from the shifter end and it never locked it in again? Pain in the ass as you have to remove a lot of crap to get to it though.
#5 ·
I did replace the brake light switch, but didn't fix it. I bridged the switch out originally and it worked once then didn't again. I tested the continuity between the contact on the switch and the set that aren't for the brake lights didn't work so I replaced the switch thinking great found it. But I was wrong.
Just spent the last hour reading on the Pulsar site (thanks big bear) and can't bring myself to read anymore about pulsars.
Tried joining the forum but they ask why you wanna join and somehow I don't think they will let me join.
I know I could just break this little plastic tab off and all will be good, but we are gonna sell it soon and it may go to a friend so don't want that on my conscience.
