If you do get the wolf, let me know and ill send ya a base fuel map to start upwith. They tell you they will do the same. But its excatlly that, and no more.. It will let ya start, but dont plan on moving anywhere.
When i was talking to them, they told me the same thing, and i aggree with what they say. its not a "rice car" all or nothing kind of boost, its real nice and even increse. (stay with me, i'm @ work atm, so im jumping all over the show) air intake. I had a standard black plastic intake on mine. First few runs on the dyno, that came off. i was told the restriction was way tooo much. I have now got a full 4" snorkle setup, running into a new airbox and "pod" style filter (plan on a sock over snorkle head when offroad) with the windows up and the wireless cranking, you can still hear that thing suck anywhere over about 1650 ish... (i think it was) You do notice a lot more power from there on up too.
injectors, no problem telling ya what they worth bud--- if i could remember.
i delt with a dude cannel dan @ N-1 AUTO Online Store... I sent out a heap of emails, and this fella offered the best help. $US735.00 was the magic number, and that was landed from the states to the perth workshop, with a 320lph pump also (ive got feeling the pump was about $US300 or so. Trying to find paperwork on it now for ya. payment was thru paypal, and tracking numbers and all that were spot on. The only thing was buddy doing the work in perth wasnt happy with the O ring seal, so we upped the size of the vitan O ring. he works in a subsea department, so we pressure tested everything and was good to go. I think they were originally ment for a skyline.
***see copy & paste infor from email****(Deatschwerks 740cc high impedance side feed injectors to suit a 93-98 RB25DET) the same injectors without any hassel. which you and i worked out to be the part number (6) 740cc Side Feed Injectors # 01J-00-0740-6. ******
Right--- Air con...
I THINK!!!!!.
i traced some drawing out, and with a few beers under my belt, and 2am before i flew back to the rig for a month away, it "seems" that the original ECU gives an input to the compressor clutch to engage. This is done by switching a negative. The wolf seems to sending a switched +12v signal down the line that is ment to be neg. Im going to go thru my drawing again for both bits of gear whilst out here with some of the electronic's guys to verafy thou. If it is, it could work out, jsut to change the switching method of that one coil to suit, then use the original positive for the compressor clutch relay to switch the relay that will be running my water pump for the water to air intercooler.
The above makes sence in my head, hopefully you can make sence of it too...
