advice on 06 patrol intercooler?
1.1K views 7 replies 5 participants last post by  truckster
hi.
good day everyone. i went to nissan a couple of days ago and a service advisor talked to me about the intercooler of patrol here in the philippines?they advised me to make a modified version of it. wat do u think guys?or are there any available bigger aftermarket intercooler?or should i buy an intercooler fan?i saw at users.bigpond.net.au/conody/intercoolerfan.thanks")
#6 ·
If you are "blowing" your intercooler, it could be because the turbo is overboosting (which is a sign you'd better get ready for some big $$$ repair bills).
I'd be getting some of the other mods done to the engine that the blokes on this forum seem to have good success with.
These include:
  • blocking the EGR valve
  • fitting a catch can for oil blow-by
  • fit a boost gauge
  • fit a Dawes valve
Good luck
Roachie
#7 · (Edited)
Check its mounted correctly. Never mount up solid finned/tubed heat exchangers (radiators / oil coolers / intercoolers) as the vibration from the engine will cause them to fail. Ensure that they sit on rubber blocks or a suspension of some kind. As you tighten the fixings ensure they pull up square and not twist or pre load the heat exchanger.
You would have to seriously over boost to blow a hole in a ali intercooler. I think the engine would be toast first !
