Barra engineering
1 reading
3.8K views 11 replies 3 participants last post by  Benny Jahmin
Anyone got an N/A barra engineered in a patrol? Looking to get it engineered but seeing that a barra is 190kw and the most powerful engine in a GQ patrol is 129kw being more than 20% more powerful than the stock engine. It would fall into the LA2 bracket and require a bunch more work. Wanted some advice on what work some people have had to do to get there rigs engineered
#2 ·
Are you still awaiting a response?
Bit reluctant to respond if you’re not hanging around
#4 ·
Basically it needs to comply with ADRs and have emissions etc at least as good as the host vehicle.
Don’t hack at the firewall and be careful- or get advice on - welding anything to the chassis in terms of engine mounts.
#5 ·
The issue I'm having is that it is going to need an LA2 certifications as the 190kw of the barra exceeds the above 20% of the 129kw 4.2L petrol stock engine of the 1997 patrols so I need brake test which is $5k and a few other tests done which is going to blow my cost out of the water for what I was expecting for the certification
#6 ·
Maybe think laterally.
Turbo the TB and you will have more power than the Barra. 230kw from memory at 16-18psi.
No conversion needed.
#9 ·
Also thinking- you’ve done 90% of the conversion? Where are you currently at? Changed diff ratios and gearbox?
#12 ·
I had a brake test done for engineering years ago. It was $400. They have a stopping bed the roll the car onto at a certain speed and hit the brakes. They do a bunch of tests, front brakes disconnected, rear brakes disconnected, brake booster disconnected, handbrake.
