Item Description
■LED Power: 120W
■ Operating Voltage: 9-48V DC
■Waterproof rate: IP 68
■12pcs*10w high intensity LEDS
■ Body Color: Black
■Color Temperature: 6000K
■Material
iecast aluminum housing
■Lens material:Toughed glass
■Mounting Bracket: Alu firm bracket
■Life Span:5000H
■Dimensions:20 inch
■Beam Type:20°SPOT BEAM, 40°FLOOD BEAM
■Theoretical Lumens Output: 11400 LM
■Operating Lumens Output: 10320 LM
■ Amp Draw(DC): 10A /12V , 5A / 24V
■ The suitable design for heating elimination.
■ The high performance of tight waterproof,dustproof,quakeproof.
■Weight: 2.90kg (Per Unit Included The Box)
■Size:508x64x92mm
.■2 year warranty.
■Package included:
1PC 20inch 120W CREE LED Light Bar
4PCS Mounting Brackets
1PC Wiring Kit
Overview
Integrated Electronic Thermal Management (ETM)
20 Inch 120W Single Row LED Light Bar Low Current Draw means no harms to battery and save gas.
20 Inch 120W Single Row LED Light Bar fine craft and easy to install brackets.
Their super efficient reflector uses patented Hybrid Technology, allowing these lights to runs at 93% optical efficiency, which is unmatched in the industry. Each LED light bar consists of two rows of high intensity LEDs, each sitting in their patented reflector assembly, measuring about 1 inch square. Each LED is independent, so if one LED fails the other LEDs will not and the LED light bar still works fine.
Its Single row of High Powered LED lights and 20 inches in length, so its both compact and powerful. The single row LED Light Bar is perfect for front mounting to any 4×4 or other vehicle, have been used by ski race teams on boats, for camping at night and in competition use, they are compact enough to mount inside on the front of most vehicles or bull bars.
This is the one I bought works very well.
