Hey gurus,
A few people on here will know I have lunched another motor.
Broke a crank this time, but that is not why I am here, cranks break, the issue is the constant blowing head gaskets, the heat cracked pistons, heads and pre combs...
I am looking to upgrade exhaust manifolds to get the gas away from the head better, I think I am running too much boost and too much manifold back pressure.
My instant thought was to run a 6boost mani, the cost I do not care about, a manifold is cheap compared to a rebuild, so if it helps, I am in.
I did some research and some respected people on here have said the longer manifold design is bad for spool because of the distance and the heat loss.
So I went hunting knowing the Radius mani has some respect and a couple of others.I see radius has just designed a new style manifold.
https://www.facebook.com/RadiusFabr.../RadiusFabrication/photos/pcb.1119192494807490/1119189531474453/?type=3&theater
and this would be similar to the 6boost one, I could not find a specific photo for TD42
http://www.patrol4x4.com/forum/atta...42394d1355351904-6boost-turbo-manifolds-suit-td-tb-42-6boost-tb48-twin-gate-jpg
I did some further research that indicates it is a toss up between equal length for pulse effect, reduced length for speed and heat retention and then the most important is collector angle to pulse into the turbo, not just flop around as it comes out of the runner into the collector.
As we all should know, 6boost manifolds are the best and his collector is a low angle, very effective piece of kit.
The Radius mani looks good, but there is no nice low angle collector angle so I think that would be very turbulent...interested to see results.
I had a look at a couple of other options but they do not look much better than my current Safari manifold.
So, my questions are:
How much spool am I going to lose with the 6 boost manifold?
Is the radius design going to work?
Is it possible testing people have done with long runner manifolds and had bad results with had more to do with bad collector design, IE, long runner = bad but good collector = good so is this going to make it somewhat comparative to the short runner manifold with a poorer collector?
Looking for some expert opinions here
Cheers, Andy
Cheers, Andy
