Vk56 V8 to a Factory 5 speed Manual
5K views 15 replies 5 participants last post by  Bob_LB
Does anyone know if a Vk56 can fit up to the Factory 5-speed manual out of a GQ/GU?
#8 ·
If you don’t have an engine already, I’d start with having a chat with Hartley Engineering. There is a port injection version of the VK56 that was used in Y62 in the GCC countries and in the Titan in the US. I believe they mainly use this version as opposed to the direct injection version that all AUS delivered Y62s have. It’s a much easier engine to control and is apparently relatively cheap out of the US. Doesn’t have quite the same power output, but probably not an issue for a GU/GQ conversion.
